What case for water cooling setup?
11 Aug 2004
London
I've got a water cooling setup with a triple radiator. So looking for a case that actually has room to fit this radiator inside it...
Any suggestions? The Corsair Obsidian 800D should be good for this but what else is there?
CM Cosmos S! I sprayed mine matt black last week and it's absolutely stunning :D If you remove the HD cage you have 10 drive bays worth of space to work with on top of the space in the roof for a 360mm rad. I have a 360, 240 and 120 mounted with loads of room left over :)
