what case HELP going nuts LOL
11 Jan 2011
Hi after much thought i finally know what i want except the case. its driving me mad lol.
heres the spec i want
CPU - Intel Core i5-2500K
CPU COOLING - CORSAIR H50
PSU - Corsair HX 850W ATX Modular SLI Compliant Power Supply
MOTHERBOARD - Asus P8P67 PRO Intel P67
MEMORY - Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
GPU - Zotac GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card
HARD DRIVE 1 - Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive
HARD DRIVE 2 - Hitachi Deskstar 7K2000 2TB SATA-II 32MB Cache
OPTICAL DRIVE - LG BH10LS30 10x BluRay-RW / 16 x DVD±RW Drive
SOUND CARD - Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card
CARD READER - Akasa BayMaster Card & Drive Reader
FAN CONTROLLER - NZXT Sentry LX LCD Fan Controller
OPERATING SYSTEM - Microsoft Windows 7 Home premium 64-Bit
Thats all i need to decide on is a case that all this will fit in and case fans.
im looking for a case thats Good looking, mid tower and quiet as possible. im not looking for a case with all flashing lights on fans etc.
i will be overclocking the CPU to 4.5GHz so needs a good airflow :)
What's your budget?
If your looking at £100+, the Coolermaster HAF X will make even your system look small! It has great airflow, so much space, all the features you would expect, but the external aesthetics can put some people off, and it's a full tower.
If you want to pay less, go for a mid tower like the Xigmatek Utgard, or the Coolermaster CM 690-II. Both have excellent build quality, plenty of space and fans, and provide decent airflow.
Fractal Design R3. Comes with acoustic foam,is super quiet and has lots of fan mounts to give future upgrade options.
coolermaster storm sniper, I have the windowed edition and it looks amazing and is also a mid tower with plenty of room :)
Hi, i have been looking around for hours for a suitable case and i have finally found Two which i really like its the Silverstone SST-FT01B or SST-FT02B without the window.
looks really smart and has good reviews.
my question is what do you think about these cases in regards to cooling and being quiet?
the fans that come with the SST-FT01B are
- Front 1 x 180mm intake fan, 700rpm, 18dBA
- Rear 1 x 120mm exhaust fan, 900rpm, 18dBA
- Top 1 x 180mm intake fan 700rpm, 18dBA
and the SST-FT02B
Top 1 x 120mm exhaust, 1200rpm, 19dBA
Bottom 3 x 180mm intake fan 700/1000rpm, 18/27dBA
out of the two cases which one would you choose and
is it worth changing the fans?
if so what fans should be changed and to what?
