What case should I get
12 Dec 2005
I'm looking for a new case that has more room than my current one. My current case is a spec 01
Budget of £100 what should I get
ATX? MATX? MITX?
Air? Liquid? Radiator Requirement? How many GPU's? Is quiet important or airflow? HDD requirements? 5.25" Bay?
Need more info ideally ;)
I would recommend the case, I have right now is Enthoo pro, its really spacious and easily to modify almost anything you want. Only downside is the front 200mm Fan which is quite loud..but keeps it cool, depending how long you run your pc for. Can easily undo the case and take it out..
but next up would be Fractal R5, its nice spacious slightly smaller and has sound dampening..its around £80 depending if u want windowed or not :).
If you like Corsair, try the 400R, 500R, C70 or perhaps the 450D.
Those tend to be around a hundred of your English squids or less and are some of my favourites. There are others too, like the 730T.
A lot of it comes down to what features you want.
I really liked the enthoo pro but I had it with my last build so I want something different
I really have no idea though..... Cable management would he really important for me
