what case, so Confused
6 Jul 2006
England, Stafford
Hi ya guys,
im planning to build a windows home server with an atom process, I have found this motherboard, the problem is, i can only find case big enough for my requirement 11 hard drive that only accept Micro ATX and ATX motherboard, will it fit in them ok or am i being silly as the board is Mini ITX
ASRock A330GC Intel 945GC Intel Atom 330 CPU Onboard DDR2 Mini ITX
http://www.asrock.com/mb/overview.asp?Model=A330GC
thx so much for your help
you can put a mini itx system into a standard ATX case, to get 11 HDD i would definatly recommend using hotswap encloses like the Icy Dock MB-455SPF then you could get the 11 hard drives in a midi tower.
Sam
