What case to buy...
20 Oct 2011
Wirral
I have at the moment a NZXT switch 810 in white. I decided that I want to change the case and had decided on a Corsair 800d. I would decide to change at the time that there are none available anywhere. I had placed an order somewhere that said they had stock (I did try OC first but they have no ETA on new stock) but it now looks like they can't supply. There aren't even many on flea bay.
So I am trying to come up with a plan B as my rig is currently stripped and in bits ready for the 800D that never got dispatched despite me getting a confirmed delivery date :mad:
What cases can you suggest - needs to fit a 60mm 360 rad with fan and a 60mm 120 with fan, dual bay res and pump and the rest of my kit in my sig. Budget was £250 (shame the TJ11 is so expensive and the 900D is so far away (remember - rig in pieces :p) )
Yeah of course - the 810 is a great case with plenty of room and I wouldn't hesitate recommending it. I just fancy a change. From a style point of view I also get frustrated that I have my 360 rad fans in the roof pulling air through and not under in push config (I know this has little to no effect on the cooling). I have had the case for 18 months now and had no problems with it at all.
