What Case?
The Antec is built better, as the Artics can have some questionable build qualities.
The PSU is the most important piece of the PC, you dont want to skimp on it remember.
Probably the Antec. The Arctic Cooling has lots of great features, but it is definitely built to a price, and given that the power supply is a Seasonic (the 350W PSU models are old stock), something had to give somewhere else. The plastics used are really hard and brittle. If you're a gentle sort, that doesn't want to open the case on a regular basis, you might be very happy, but if you like to change components on a regular basis, I would urge you to look at the Antec instead.
I'll probably go for the Antec then, but thats another £10 on top of the already riding price :(
I know it doesn't sound like much, but I'm on a paperround.
I ordered the Antec SLK3000B yeasterday - should be here tomorrow.
I did a lot of research and the the 3000B seems to be the best budget case around. I'll post feedback when its all set-up and running.....
Rich
