If so, i have that case and have been contemplating the 350D too. It depends on what you want really.
The 350D can easily accommodate a h100i and GPU's in SLI. The Tj08-E can't.
(not that i've had the 350d) Im pretty sure the TJ08-E has better build quality and the cooler performance is unreal. That front 180mm pushes a HUGE amount of air. If you are air cooling (either low/mid orhigh end) the TJ08-E is set up better for that purpose.
So basically, Do you want a H100i and SLI GPUs? If yes; 350D
Or Are you going to go air cooled with a single GPU? If yes: TJ08-E
