Hi,
Not posted in this section before so go easy
I'm after a new case that will reduce the noise levels of my CPU and GPU fans primarily. At the moment im running on an OcUK Value case
Eww.
I dont have any fans on my case either (if you could recommend some that would also be great). I'm also ordering the Artic Cooler 64 Pro too, so would that effect how the airflow is managed? (because of the way the fan is upside down compared to the stock cooler which is looking straight at you when you into into the case)
I'm looking to spend a relatively small amount due to the fact i'll probibly need fans and the AC64 Pro. Idea price is about £60, can be persuaded to go a little high should it be worth it, but at the end of the day it is only a case.
What can you recommend?
Thanks.
Eww.
Thanks.
