Processes can cause a slight fluctuation in the temps depending on what core is being used. Windows updating or something loading in the back, is check the core usage % and refer that to the core that's doing the spiking. I don't the core is idle when the temp shoots up, more likely it is processing something, and probably around 50% usage going by your temp ( just a guess)
Hwmonitor is perfect for that
For my example, why would a process like windows update cause temp fluctuations 10-15 degrees higher than the linpack stress test.
The temp behaviour is very different to what I have had in the past.
Normally, I would do occt and linpack. Linpack and Intel burn test would give me my highest temps. They would get to the max temp and stay there, with maybe 1 degree variance. Example 70degrees.
If I gamed, or used my pc normally, the highest I would see would be 55-60.
Today, if I use occt or ibt. My temps will hit 75 for 1 second then back down to around 55-60. This during 100% load.
Linpack behaves as I expect, it shoots to about 58 within a minute, and stays there without spikes or variance. Gradually creeping up to 65 after an hour and my water has hit equilibrium.
If I game, or use my pc normally, the highest I would see will be 65-70. Higher than linpack at 100% after one hour.
This just seems odd compared to all previous experiences. Also from around the Web, people with a similar setup report highest temps whilst gaming as 55-60, mine is this on average with max 70.
Is it possible, someone with a 6700k could post a screenshot of a graph with core temps over time during a cpu: occt test? It will give me a better way to see how mine correlates. Thanks.
