What causes my PC stuck after power on & how to fix it?
My PC :
Desktop Acer Aspire T3-715
Windows 10 Home 64-bit, updated to 21H1
Intel Core i5 Processor 6400
NVidia GeForce GTX745 4GB
Hard Drive : SATA3 1TB & SSD 128GB
Memory : DDR4 8GB
DVD-Super Multi drive
Card Reader
Integrated LAN 10/100/1000
Monitor : SamSung SyncMaster 933sw
Installations:
1.Windows 10 Home
2.Photoshop cc 2021
And other small apps such as Faststone Photo Viewer, SuperAntiSpyware, etc.
Uses:
Editing photographs, RAW files, shot by Canon DSLR & Sony a7 mark2.
Digitizing negative images & editing them, RAW files.
An hour or two on internet, basically YouTube, everyday.
Environment:
In a suburb on a hill, there is always a breeze or air conditioning & the room is clean & spacious.
What happened :
About two months ago, Windows updated to 21H1.
Not long after the update, my PC started having issues.
At first, there was no mouse or dead mouse after booting into Windows.
Then, crashes at work & BSODs & re-starts automatically . . . .
Twelve days ago, the machine was stuck 2~3 minutes after power on, stuck at "acer" logo.
The situation now :
When power cabled is connected to the machine & start button is pressed,
1.start button turns power on,
2.light in front panel is on,
3.CPU & graphic card fans turn,
4.monitor lights up & shows "acer" logo & stops at this point,
5.Press the start button again, it turns the power off.
Note:Except for these 5 functions, EVERYTHING ELSE IS DEAD.
Here is the photo:
https://photos.app.goo.gl/NNTFuoEE5Lz5Pmx58
Tests I have done (learnt from Googe search in the last ten days) :
1.Test each device, disconnect it & turn power on.
2.Test the CMOS battery,
2A.Disconnect power, then press & hold the power button for 3 minutes,
2B.Disconnect power, take the battery out of its socket for 8 minutes,
3.Test BIOS, press start button on & off quickly & repeatedly.
4.Test BIOS, disconnect SATA & SSD then turn power,
5.Tesd BIOS, disconnect all the devices, connect power only, turn power on,
6.Test main board, pull RAM & graphic card out, then switch power on,
7.Test the monitor, change monitors, 2 other brands & specs,
8.Test the keyboard, change keyboards,
9.Test the mouse, change mouse.
Result of these tests:
1.Only test 6. ended with a positive result, a continuing "B" signal.
2.All the other tests did not make any difference.
3.There is one test I did not do, i.e., to jump the BIOS. There is no cap on the pins & they look rusted.
It seems that there is nothing I can do anymore.
Help, please?
Thank you very much.
Diano
My PC :
Memory : DDR4 8GB
Card Reader
Installations:
1.Windows 10 Home
2.Photoshop cc 2021
Uses:
Environment:
What happened :
The situation now :
Here is the photo:
Help, please?
Diano
