What charger for this LED egg lamp?
16 Nov 2002
The Moon
Hi all, bit of a random one this but hoping the brains of GD can help me procure the correct cable I need.
I have an LED light-up egg which has an integrated battery which is charged via USB or mains. Unfortunately I've misplaced the charging cable so can't charge it anymore so was wondering if any of you folk on here can help me identify a suitable cable to charge it up or just act as a mains power source for it.
The only thing I've got to go off is a picture of the jack fitting on the bottom and the actual egg itself, there are no markings on it for wattage/amps/volts or anything so im a bit stuck really with what to buy!!!
Any help massively appreciated!!!!
If you can work out if it is 2.1mm or 2.5mm jack socket required you can pick up a simple USB to jack socket lead for a couple of quid. Plug this into any USB charger and you are done.
If you can't work it out just pick the bigger and if it is too loose you can buy a converter for another couple of quid.
Or just get the 2.5mm and the converter as at some point it'll come in handy as guaranteed whichever adaptor you have it'll be the wrong size.
