- 12 May 2011
- Southampton
Feel free to move this to the wc section if you disagree with my 'you need Case knowledge not wc knowledge' logic
I'm after a closed loop for my Haswell build when it is released- sort of a 'babies first watercooling setup'. I have a shinobi non-XL and I've heard a h100i, despite my case having 240mm width on the top fan mounts, won't fit due to not enough depth between the top of the case and the motherboard.
Does anyone know what closed loops will fit? And if said closed loops are any better than a £70 air cooler?
