What colour fluid to get?
18 Mar 2008
Hi guys, here's some pics of my current setup:
http://forums.overclockers.co.uk/showthread.php?t=18178985&page=10
(sorry, I'm unable to embed pics atm)
I'm going to get some Mayhem's Dye to put into the system. I'm definitely going to get some Deep Blue, and probably some UV blue as well (clear in normal light, but properly blue in UV).
However, obviously for the UV blue to have its effect, I'd need some UV light. The problem is that I'm not sure whether having violet cathodes and led's would actually suit my current colour scheme.
What do you guys think?
Thanks
The blue and UV Blue sounds good, in regards to the uv cathodes they are violet but depends how much you could hide them out of sight of your window. I have three uv cathodes in my case and unless viewed from very acute angles you can't seem them but lights up my tubing perfectly.
Okay guys, I think that throws the UV idea pretty much out of the window. what about getting some sort of green? Maybe acid green? I think that'd look decent with my current colour scheme too.
