What colour for this loop?
11 Sep 2014
Suffolk, England
So, I'm currently running my system on simple bottled water. I wanna colour it up though & want something that'll either match or compliment my colour scheme. So, based on this picture, what do you guys suggest would look good in here?
I think you'll find it hard to match the gold, you might be better with black.
I find it terribly disconcerting that that asus usb appears to be floating......
like...straight up creepy...
+1 for Black
There was a build log where someone had used a black/metallic grey combo that remained separate within the loop (not describing it well) I'll see if I can find the log as that could look sweet in your build...
Well gold is 51/43/0 r/g/b so maybe you could make it up from the dye? Then use black to darken it till it looks like a thick gold? You'd only need 3 dyes at max to get a good gold.
You can make it simplier racios of 17/14/0 but the colour won't be as golden.
Don't mayhems make personalized dye (on request) for builders if you send them a sample of the colour you're trying to achieve?
I've sent them a message asking them about this service. If possible I'll ask for a few samples of different colours they make up for me & I'll decide then which one looks best.
Black or Sunset Yellow :)
I was considering Sunset Yellow actually (:
+1 for Black
If you find the log/thread, post it to this thread please. I'm really intrigued!
Make sure to get something that will add protection from corrosion/aliens not just dye.
Thanks for the tip (:
What can I say, my pc has a tail...
Ok, lots of searching but found it: http://forums.overclockers.co.uk/showthread.php?t=18619726&page=7
It's Jameswalt1's epic "Parvum Warfare" build. If you don't have time to read through, he used Mayhems Aurora 2 mixed with Mayhems Oil Black concentrate to get the effect. A black/gold mix (if possible) would look awesome!
HTH
Oh, yeah I get what you mean now aha. I imagined something completely different but yeah that's kind of what I've got in mind, but golden! Something special may be happening soon btw, so keep an eye out on my build log over the next few days ;)
Look forward to it! I thought instead of picking between black and gold, you could have both with something like this...
Go for clear. You'll thank me if you ever spill on the carpet :)
BTW I hope you mean distilled water rather than bottled drinking water. You definitely need some anti-corrosion additive even if it is distilled.
