- 10 Feb 2011
What comes with a pre built barebone system and what extra do you need to buy?.
I no buying a pre built barebone is not fully making your own PC but its a start and was thinking of buying this as a first project.
http://www.overclockers.co.uk/showproduct.php?prodid=FS-268-OK
I already have a Sprae Hard drive which is a Barracuda 500GB, Windows 7 pro retail so i can just use this. I will buy a graphic card at one pint but at the moment i have a XFX 5700 graphic card and just swap that round. Money not a problem but i do want to go low as if it does break i havnt loss too much.
Just wanted to no what comes with it or what else i need to make it fully work. Motherboard, psu fans cables etc.
EDIT:::
On the main page it does say it comes with.
System Specification
- Case: OcUK EZCool NA-705 microATX case - Black
- Motherboard: Asus M5A78L-M LX (Socket AM3+) DDR3 Motherboard
- Power Supply: OcUK Value 500W PSU
But on the comments some one says that you dont get any fans so what exactly do you get.
Thanks.
EDIT:::
Thanks.
