What computer specs do i need for GT Legends?
12 Dec 2005
Hello.
Please can some one tell me what computer specs are needed in order to run GT Legends, i cant seem to find it on google.
Thanks.
- Denic
Off the back of my game box
1.3 GHz Intel or AMD Equiv
512MB RAM
2.5GB HDD Space
DX8.1 compatible card with 64MB
Recommended
2GHz Intel or AMD Equiv
1GB RAM
DX9.0c compatible card with 256MB
512MB RAM
2.5GB HDD Space
Recommended
1GB RAM
I expected it to be higher than that, my pc should smash them specs.
Do you have this game? If so, is it good?
I do have the game, it is very good, in my opinion.
It really depends if you like your driving games, as it's not a game to be played without a wheel to be honest (Though some use a joypad).
It's a sim game, so it's got a lot of realism involved, it's certainly no arcade game anyway.
What's your system spec? There is a demo available, download it and see what you think of the game, and how it runs.
I've managed to download the demo, ill open the game, and go to race, and my computer will just crash. All of it, so i will have to restart my PC.
Is something conflicting?
- Denic
Installed that,. and it still crashes on me
You guys are winding me up? My cd drives are opening on there own for no reason :confused:
lol wow... i dont think they're messing you around man, i just think that starforce and its craptactularness has struck again.
Nope, not winding you up at all. Very strange problem, not heard of that happening at all.
Are all your drivers & Direct X up to date?
Hi mate,
Just to say these dudes are Not winding you up.
The drawers opening indicate a driver conflict with Starforce/CD drives.
What Anti virus are you using as there are conflicts with some AV drivers as well.
Check your driver list for the dreaded yellow triangle.
It's also quite possible that it's just a resolution issue. Set your monitor/system to the default res and try it before doing the above.
I've just gone into device manager and updated them yellow triangle - things.
It was USB drives or something, im just downloading the demo for gtl again, as i deleted it last night,
I will also try that thing with my resolution,
Thanks for your help.
- Denic
Paul -C- said:
Same thing happened to me. Turned out I had to update my motherboard's (Asus A8E32-MVP Deluxe) BIOS.
If only i knew...
What motherboard was in my PC...
Where to get the drivers.
Go on! LAUGH!! I AM TOTAL NUB! :p
I don't have a clue what to do with that programme.
Well, i know my system specs lol, i "think" ive found out what my mobo is, but i dont have a clue where to search for the driver for my mobo.
Thanks
