I bought a second hand set of 5.1 speakers and sub from ebay. They are Logitech Z-5500.
They arrived today and I have found out the control pod has a VGA connection for the display.
I have a GTX 580 and an Asus Maximus V Gene motherboard. As the graphics card and motherboard doesn't have a VGA connection I thought it would be simple case of buying a VGA to DVI connector.
According to they guy in Maplin I spoke to that is not the case. He did try to sell me some sort of converter box that he said would work but it was £50.
Surely there is a much cheaper option I can do?
These are photos of the control pod and the VGA connector. As you can see the control pod has a female VGA connection.
image hosting 20mb
image hosting over 5mb
What do I need to buy to get my control pod connected to my graphics card?
image hosting 20mb
