I have a coolermaster elite 430 and a FX6300 but will probably be changing to 4770k.
I was going to go water cooling then I saw a thread where a D5 pump failed and coolant went everywhere, so this has kind of put me off, I think lol.
Then there's AIO's as they are sealed they are less likely to leak I'm guessing? I really like this one
http://www.overclockers.co.uk/showproduct.php?prodid=HS-069-ZA&groupid=701&catid=2330&subcat=2355
and with the nanofluids if it does leak would it do the same damage as others?
Or there's the big air coolers such as
http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-PT&groupid=701&catid=2330&subcat=2348
If it will even fit in my case? But do they always cover a memory slot and sometimes even a PCI slot? Obviously with having to change the motherboard soon I have to consider this.
I suppose budget is somewhere between 50-150. Under 100 would be nice though
