richyp said:im hopefully getting that same motherboard mate. did ** core 2 work straight away with the DS4? or did u hav 2 put an old P4 in and update the bios first? thx.
richyp said:thx man thats mint. Im also deciding between the 2gb giel low latency or corsair. the giel is cheaper but i heard some are havin issues with the cas etc. lol *** u think?
flibby said:Arctic Cooling Freezer 7 Pro, kinda loud for me though as I don't have SMART fan on so it's at 2500 RPM. Runs my 6400 @ 3.2 Ghz, 40c. idle / 52c load (enabling SMART fan makes it hella quiet, but the temps rocket, about 15c on idle and 10c on load). Great cooler overall however.
ive got the 9700, on its lowest setting, idles at 29-30richyp said:Gettin a E6600 very soon, what cooler has every1 got on theirs? for the best OC. not sure if the zalman CNPS9700 is worth all the money??
valerian said:ive got the 9700, on its lowest setting, idles at 29-30
but-ive put loads of freezer 7 pros on allendale 1.86's
monkeypants said:My AF7 is lame, 47C idle in a 20C room at 3.15Ghz? I'm getting a Titan Vanessa-L. That should sort my temps out.
I've lapped the IHS, but I'll do it some more when the Titan comes tomorrow.WJA96 said:Sounds like your IHS might not be flat then. AF7's are very, very good. It will be interesting to see what the Titan Vanessa does for you.
