If you really want a closed loop water cooler but cant fit a 240 rad , i would go for the Antec 920 bit expensive at the moment but far better than the other's , a bit noisy on stock fans but includes a good software package that can help with fan noise, or swap out the stock fans at more expense, if not i would stick with air and remove the tall heatsinks off your ram its not really needed.
No experience with either of these. But units like it! Intel trialed one years back. Use coolit systems ones as well. Most use a back plate and the pump screws down into that.
Antec has a thicker rad and higher airflow fans so would work a tad better than the corsair. But its a fair bit above your orignal budget. I would say the H60 will do just fine!
