What could my new build pc run and what settings could it run games at
Permabanned
31 May 2014
This is my build please could you tell me what games that could run and at what settings they would run good at :)
CPU:AMD FX 6300 black edition
Motherboard:Gigabyte 990XA-UD3 Memory:8gb DDR3 1333mhz
Hard Drive: 1TB S-ATAlll 6.0GB/s
Graphics card: AMD Radion R9 280x 3GB
PCU: 650 W corsair vs
Case: Zalman Z11 plus
Thanks for all the help in advance
Yep I would expect over 60 FPS for most games on ultra settings. Also get a cooler and overclock that CPU
What about the day z standalone alone would that be smoother when it is furnished? But thank you very much for all your help :)
Dayz is a notoriously badly optimised game I once watched a Frankiein1080p vid at some point this year and he was getting below 30 fps in certain areas and his machine is way over kill with an sli config and an intel-e cpu
Ok well thank you all for your help. Would you recommend that I build the pc or get it pre built?
And I am a console gamer (no hate) ;) and I was wondering how easy is it to switch from console to pc?
I have literally just done this at the weekend, i bought all the parts after a lot convincing on here to do it myself. If you are a bit handy and watch a lot of videos and research the parts its not too bad at all and its awesome when it boots up (make sure you connect your monitor and power supply correctly first unlike me)
I think its worth it i had a ps4 and there are no games at all on it its just been collecting dust and there isn't much coming out for a while... its on ebay as we speak
Ahhhh ok well yeah I will definitely think about doing it the only reason why I have not done it yet is because
1. Because I dont know if all the parts will work together or what not
2. Because I dont want to brake any of the parts or shock them so they dont work :/
if you are really not confident in it then it might be best not too, but give it some time and watch some youtube videos then make an call on what you are going to do.
