What CPU and GPU temps do you get?
3930K at 3.4 34C Idle 42C full load (prime95)
3930K at 4.6 (1.34V) 41C idle 48C full load (prime95)
3930K at 5.0 (1.495V) 46C idle 55C full load (prime95) max it has been is 68C but since the weather has got a little colder, it has helped keep my bits cold.
680 SLI temps 28c Idle 55C max at 1.495V (since the cold spell) (not been tested under warm conditions)
I was surprised at how much ambients can make a difference. Generally it is around 23C indoors but if I open the door to let the cold air in, I can run at 5GHZ on my cpu and temps do not go above 45C
Not much difference between idle and full load temps on the 3930k?
No Dave. When I was using just a 360 Rad, temps were hotter but after adding the 240 also, temps are excellent. I ran an hour with prime95 to see the max and as soon as I stopped prime, temps were straight back to normal.
Same goes for the GPUs :)
Just let mine rest for an hour and these are my temps, a bit lower on the GPU than I thought. Room temp 21c.
Look good for a 240 rad
Here's mine-
2600k 5.0 (1.4v)
SLI GTX 680 @ 1200
Prime 95 with EVGA scanner bench for 30 mins
CPU 63c
GPU avg 49c
room temp 25c
That's all on a RX480 rad with SP120's
2500k @ 4.6 (1.296v)
Idles 30-33c
8 hrs + prime 59c max
7950 idles at 31-32c
never saw it go over 51c in any game or test
+ my room always kinda warm
i7 930 @ 4ghz (1.29375) idles 35c to 40c max 55c
GTX 580 @ 925mhz core idles 30c to 35c max 50c to 55c
