What CPU block?
  • Thread starter Thread starter los
  • Start date Start date
los
los
26 Jun 2011
Great Yarmouth
I currently have 2 x 240 rads and a D5 pump cooling my cpu and GTX780.
Looking around the supremacy evo generally comes out on top (I have a supreme ltx) Are there any others that I should be looking at for a similar price £50 or less?
Check the XSPC Raystorm Pro and EK Supremacy MX if you are ok with metal/semi-plexi tops. Top notch performance also at lower prices.
It's actually a plexi top I'm after. I'm guessing the mx can't be as good as a supremacy evo?
I like my Alphacool NexXxos XP3 block... used it on multiple builds now and bought myself a second one for my spare machine.
Slightly, but yeah not as good. Among Plexi versions, the Heatkiller IV Pro and the new Koolance 390 are as good as the EK Supremacy Evo but all on the more expensive side of 50 GBP. Not much to go between them though. Another option would be the Bitspower Summit but it has some compromises as well.
