- 7 Feb 2010
To cut an extremely long story short I need a new CPU as I am capturing HD and it has my CPU at 70%-100% within 5 seconds!
With my mobo I am not going to get the power I need (Gigabyte M61PME-S2P) so I am looking at going for Intel i5 or i7.
This are the 2 packages I was looking at:
a)
www.overclockers.co.uk
b)
I have spoke to a few people and they have said get the Asus P7P55D, i5 750 and 4GB 1600MHz dual channel ram and just over clock myself for about £70 less than that package. My question is do you think I should go for this set up for HD capturing and rendering or would you recommend something else?
I will put the mobo, CPU and Ram into my current build which is:
Antech gaming case
ATI Radeon 512MB 4850 GDDR3 PCI-E
Seagate barracuda 500GB 7200.12 (I might set-up Raid 0 if I need to record uncompressed)
Corsair VX 450W power supply
Is all that fine?
Items which shall be replaced:
Gigabyte M61PME-S2P
Kingston hyper X 4GB DDR2 800MHz ram
AMD Athlon II dual core 245 - 2.9GHz
a)
homepage.seo.open_graph_title
Leading the way in bespoke PC systems and PC gaming, any and all of your components & peripherals needs are met with our vast range of products and services.
b)
Antech gaming case
Is all that fine?
Gigabyte M61PME-S2P
