What CPU's for this mobo?
5 May 2006
PSN
A friend it looking to get a new cpu and has the following, what cpu's will go in ok?
its a parkard bell IMEDIA 1610
mobo seems to be
Columbia VI (GA-8SIML-NF6) Ver 2.0
CPU Support
* Socket mPGA 478B
* Supports Intel P4 FC-PGA2 (Flip-Chip Pin Grid Array), 1400 MHz to 3060 MHz.
* Warning: not all of the above processors have been qualified.
* 100 MHz (x4 = 400 MHz) data bus support (Quad-Bumped technology).
* 133 MHz (x4 = 533 MHz) data bus support (Quad-Bumped technology).
Upgrading pre-built PCs is always problematic and difficult to give suggestions on, no telling his PC will even support a CPU upgrade and BIOS updates would be very hard to come by and there is the question of cooling and fitting the thing.
Also that whatever you upgrade to in systems like that there will always be another bottleneck that stops you getting decent performance and CPUs that max out old motherboards tend to still have a premium price that isn't proportionate to the speed boost.
Sorry I can't give any more specific advice :)
mobo seems to be
CPU Support
* Socket mPGA 478B
A 3.06Ghz Pentium 4 533 FSB like this for example : http://processorfinder.intel.com/details.aspx?sSpec=SL6S5
should work fine as it supports it.
