Assuming the rated 12V, four earth lines. What current can it reliably handle before the wires run too hot and it all goes terribly wrong?
I can't find the specification for this online, so currently my only option is to cut one of the cables off and try to work out what gauge it is. I don't want to do this, so hopefully one of you knows where I can find the answer.
Many thanks
Jon
Many thanks
Jon
