what devices are on my network IP wise?
  • Thread starter Thread starter Lex
  • Start date Start date
Lex
Lex
26 Dec 2002
NW London, United Kingdom
How do i find the IP of a device on my network or a list of devices?
plz
start > run > cmd >
ipconfig /all
to find another device if you know the name you could ping that device
so
start > run > cmd >
ping xxxxx
mike1210 said:
start > run > cmd >
ipconfig /all
so
start > run > cmd >
ping xxxxx
that just shows the IP address the the information related only to my machine. not the other devices on the network
what i'm looking for is a to find out a specific device on my network such as a camera's IP address as i was not provided with the default IP.
doran1801 said:
won't the login page of his router tell him this?
to get to the login page i'd have to be able to connect to it by IP to see that login screen so no it wont tell me.
its okay because i used that angry ip scanner proggy and it worked. good find! will help me in the future:) providing in know the IP range which as im a techie i do:)
echo off
>> report.txt echo *******************************************************************************
>> report.txt echo.
>> report.txt echo.
set /p userdata=Enter notes for this location:
>> report.txt echo %userdata%
>> report.txt echo %date% %time%
if [%1]==[] goto NOARG
goto GOTARG
:NOARG
>> report.txt echo.
>> report.txt echo ******** IPCONFIG COMMAND ********
>> report.txt echo.
ipconfig /all > ~ip05.txt
>> report.txt type ~ip05.txt
echo FINDING CURRENT IP ADDRESS
ipconfig | find "IP Address" > ~ip01.txt
for /f "tokens=1-2 delims=:" %%i in (~ip01.txt) do echo %%j> ~ip02.txt
for /f "tokens=1-3 delims=." %%i in (~ip02.txt) do echo %%i.%%j.%%k> ~ip03.txt
>> report.txt echo.
>> report.txt echo ******** ROUTE COMMAND ********
>> report.txt echo.
>> report.txt route print
>> report.txt echo.
>> report.txt echo ******** NSLOOKUP COMMAND ********
>> report.txt echo.
>> report.txt nslookup . | find "."
>> report.txt echo.
goto REPORT
:GOTARG
> ~ip02.txt echo %1
goto REPORT
:REPORT
>> report.txt echo ******** PING COMMAND ********
>> report.txt echo.
echo PINGING HOSTS IN SUBNET
for /f %%i in (~ip03.txt) do call :PING %%i
>> report.txt type ~ip04.txt
>> report.txt echo.
>> report.txt echo ******** HTTP WEB SERVERS ********
if not exist %0 goto NOHTTP
>> report.txt echo.
echo CHECKING FOR WEB SERVERS
type %0 | find " " | find /v "not me!" > ~ip00.vbs
for /f %%x in (~ip04.txt) do call :HTTP %%x
type ~ip13.txt
>> report.txt type ~ip13.txt
>> report.txt echo.
:NOHTTP
>> report.txt echo ******** NBTSTAT COMMAND ********
>> report.txt echo.
echo CHECKING NAMES WITH NBTSTAT
for /f %%x in (~ip04.txt) do echo %%x & echo %%x >> report.txt & nbtstat -A %%x | find "Registered" >> report.txt && echo %%x>> ~ip11.txt
>> report.txt echo.
>> report.txt echo ******** NET USE COMMAND ********
>> report.txt echo.
echo CHECKING SHARES WITH NET USE
for /f %%x in (~ip04.txt) do call :NETUSE %%x
net use | find "\\" > ~ip10.txt
>> report.txt type ~ip10.txt
>> report.txt echo.
>> report.txt echo ******** NET VIEW COMMAND ********
>> report.txt echo.
echo LISTING SHARED RESOURCES WITH NET VIEW
net view | find "\\" > ~ip08.txt
type ~ip08.txt
>> report.txt echo ----------
>> report.txt type ~ip08.txt
>> report.txt echo.
if exist ~ip11.txt for /f %%x in (~ip11.txt) do call :NETVIEW %%x
>> report.txt echo.
>> report.txt echo ******** ARP COMMAND ********
>> report.txt echo.
>> report.txt arp -a | find "-" | find /v "invalid"
>> report.txt echo.
>> report.txt echo.
If not exist ~ip06.txt goto NOSHARE
set /p userdata=View remote shares (y/n)?
if [%userdata%]==[y] for /f %%x in (~ip06.txt) do start \\%%x
:NOSHARE
if not exist ~ip13.txt goto NOWEB
set /p userdata=View web sites (y/n)?
if [%userdata%]==[y] for /f %%x in (~ip13.txt) do start http://%%x
:NOWEB
:CLEANUP
echo y>~ip09.txt
type ~ip09.txt | net use * /delete
del ~ip??.???
goto :EOF
:NETUSE
net use \\%1\IPC$ "" /USER:"" | find "success"> ~ip12.txt
if not errorlevel 1 echo %1> ~ip06.txt
goto :EOF
:HTTP
cscript.exe ~ip00.vbs %1 >> ~ip13.txt
goto :EOF
On Error Resume Next
Set oHttp = CreateObject("WinHttp.WinHttpRequest.5.1")
oHttp.SetTimeouts 1000, 1000, 1000, 1000
oHttp.Open "GET", "http://" & WScript.Arguments(0), False
oHttp.Send
If err.number = 0 Then Wscript.Echo WScript.Arguments(0) & " " & oHttp.Status
Set oHttp = Nothing
:NETVIEW
net view \\%1 > ~ip07.txt
type ~ip07.txt | find "\\"
type ~ip07.txt | find "Disk"
type ~ip07.txt | find "\\" >> report.txt
type ~ip07.txt | find "Disk" >> report.txt
goto :EOF
:PING
for /L %%x in (1,1,254) do echo %1.%%x & ping -n 1 -w 50 -i 6 %1.%%x | find "Reply" && echo %1.%%x>> ~ip04.txt
goto :EOF
forget everything else use the above, copy that save as a bat file and run it, this bat file will give you details, very power full tool.
