what diameter tubing?
Man of Honour
26 May 2012
so i'm deciding whether to watercool my rig.
just a quick questiong re: tube diameters.
what gives? how do people make their choices and any considerations to take into account?
Tube internal diameter (ID) doesn't really matter that much. What matters more is aesthetics + routing i.e. will it kink for the radius bend that you need the tube to do.
Personally, I think the thicker tubing 1/2"ID 3/4"OD tubing looks the mutts nuts but because I need my tubing to do some fairly tight bends, am running 3/8"ID 1/2" OD
I prefer the 7/16 tubing because of how tightly you can get it over 1/2" barbs and not need to use ugly hose clamps.
I actually prefer the look of 7/16 tubing forced over 1/2" barbs than compression fittings as well, out of the 3 watercooled PCs I've done I liked the 7/16 over 1/2" the most.
16/11MM WITH compression fittings XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Chrome) + XSPC 7/16" ID [16/11mm] High Flex Hose.
The tubing is a good tight fit even before you tighting the screw ring up.
