Long story short, got 128g SSD with my PC 1 year ago after a few issues i upgraded to 256g SSD and was to send the 128g back but ended up buying it as well. Run my 256g SSD for a year and i managed to get some annoying pop up on it (probably from porn sites ill admit) Googled that and no real answers onto how to remove it so thought ill do what i wanted to do with the 128g and use it as my boot drive and put all games on the 256.
I reloaded windows 7 pro onto my 128g SSD. All went fine but i noticed i had a 100mb partition on (this possibly comes from the OC build of my PC?) So in management i disabled this as primary and made the other partition with windows install on it primary ? Appeared no problems.
Had to do a reboot for some reason and got the "no boot manager" screen of death, googled on other machine and told to create boot disk etc etc but no joy, windows was having a proper paddy on and wouldnt repair or anything
Even using command prompt it wasnt allowing me to change boot form CD.
In the end i had to change bios setting to boot from disk so i could reload windows 7 pro again, in that process i deleted the partition and formatted the 128g SSD and installed windows with no problems. Rebooted numerous times now to reload updates etc.
Just after some answers really i have installed a few windows in my time going back to 2000/XP but not really a computer know it all if you know what i mean. Windows 7 has always been a doddle in my terms, vista used to take 4-6 hours i can pop windows 7 on in about 2
Why was 100mb partition put on originally?
Why did disabling 100mb partition break boot up?
Why didnt the PC see the windows disk in the CD bay and boot from that?
Sorry if this all sounds a bit nooby but never really had this problem before
