Did a quick google and Linx doesn't show anything?Could run LinX to stress test it to check it doesn't overheat I suppose.
Not a lot, AMD NEO 1.6ghz,2gb ram,320gb hdd and ATI X1250.How much for? What are the specs? Check the cosmetics. If it's slow e.t.c. Personally I would never use eBay for buying hardware or software from. People bang on loads of stolen stuff on it.
Ok, prime can run off a usb yeh?Prime to check full load temps and for stability - but probably need to a quick test.
CPU-Z & GPU-Z to confirm specs and the cpu speed does increase when stressed.
Ok,If it boots and doesn't make any horrible grinding noises it'll probably be alright. The battery may be worthless, but that's difficult to check quickly. If prime doesn't make it switch off then it probably isn't full of dust.
It doesn't have a nvidia gpu built in does it?
Thanks mate, i have just wrote that downDoes it have windows 7? If it does then you can use this to check the status of the battery.
It will produce a report that lets you know the designed capacity of the battery and how much of that designed capacity it is managing to charge to now.
That's a fairly low wattage laptop, hence a cool one and probably not a dead one.
Prime, cpuz, intel burn test ( = LinX = linpack), hw monitor can all run from a usb stick with no problems.
Thanks mate i will get some of them stuck on a usb
What is the latest IBT?
I am not entirely sure if laptop is 32bit or 64bit..does it matter which version i download?
