What do I need to boost performance in supreme commander?
yes, your CPU would be the bottleneck without a doubt, it is recommended you have a Quad core for it
Well to be honest your GPU aint best either ....
7800GTX is pretty old so I guess both GPU and CPU might be holding you back here.
from cheapest options, E7200 (or 8400 is really cheap right now, not much more, but then u will need better mobo as well) + GAP35DS3L + HD4850 should give you a huge boost.
Would the E2200 not be a better choice for overclocking considering that it has an 11x multi?
