what do i need to run Rainbow 6 vegas
Intel Core 2 Extreme X6800 (2.93GHz/4MB)
Motherboard: EVGA nForce 680i SLI
Intel BadAxe
Chipset: NVIDIA nForce 680i SLI
Intel 975X
Chipset Drivers: Intel 7.2.2.1007 (Intel)
NVIDIA nForce 9.35
Hard Disk: Seagate 7200.7 160GB SATA
Memory: Corsair XMS2 DDR2-800 4-4-4-12 (1GB x 2)
1337z0r said:
My X1950XT ran it fine with all the settings high and aa maxed. on 1280x1024.
AA doesn't even work on Vegas :confused:
It doesn't exactly run fine on a 19** XT, it will be playable in some areas and really really terrible in others. I would reccomend the 8800.
I played on high @ 1680x1050 no AA, 30fps with frequent drops to 15fps and below.
It seems to get much worse a few missions in, whe you get into the cassino.
Ran very smoothly for me on a X1950Pro512 @ 1360x768. Needs the V1.05 patch as that makes it very stable and also improves performance.
thx
do you play multiplayer R6V?
any other fps games you recommend for high spec cards?
