What do I need to use a set of speakers on 2 computers?
Permabanned
7 Nov 2002
Over there
Hey,
I need some kind of cable splitting thing that I can plug my 3.5mm jack from my speakers into, that then has two further 3.5mm jacks that i can plug into my two laptops.
Will save me having to plug the speakers into the different computers when i switch.
What do i need?!
Thanks :D
So its not a case of simply splitting the one cable that coems from the speakers into two standard 3.5mm? I dont mind of sound would come out of both computers at the same time.
hmm you mean the adaptors? I think they do something funny to the noise & impedance. They're only a couple of quid, and those QED switch boxes aren't cheap £30-£100
Search for "QED IX20 " I think that's the right box...don't take my word for it
Yes, you shouldn't join them both together, you must use a switch. The boxes needn't cost that much though :confused: , how are your DIY/soldering skills :)
