What do I need to use cordless drill as a screwdriver?
24 Sep 2007
Hi Guys
I'm about to buy a Worx 373.2 cordless drill (let me know if you have any comments). I want to use it to drive screws, but I'm not sure exactly what drill bits I need or how they are used, I want to buy the right stuff.
I understand you get the various tiny screwdriver heads, but what is the adapter called that they fit into, and what end should it have to fit a cordless drill with a keyless chuck? What drill bit set can I buy that has this adapter?
I know there is a difference between a cordless drill and an impact driver, so I want to make sure I buy the correct screwdriver adapters for the cordless drill. I think the cordless drill adapter may have a round end whereas the impact driver ones are hexagonal, which I don't want.
Thanks
impact driver bits will all work in a normal drill/driver.
proper name for the adapter, magnetic bit holder ??
magnetic bit holder will have a hexagonal shaft most of them do if you insert the adapter into the keyless chuck it will tighten and grip the holder fine.
then you just insert whatever bit you need for whatever type of screw you are driving into the end of the holder and the magnet holds it in.
