what do i need
5 Jan 2012
hi i have just completed fitting my vi2 kit at the moment it is only cooling my cpu. i7 2600 oc to 4.6 ghz at 1.344v. i want to add my 3x gtx 580s apart from the vga water blocks what else do i need i have a nzxt phantom case
i have a Corsair AX1200 i would have mount the rad on the outside of the case. where would i fit this into the loop and would the pump i got with the V12 kit be enough for the 480 rad and 3 graphic cards
Placement of the rad and gpu blocks in the loop make very litle difference to the temps so just make it the easiest route you can.
Yes, the pump would be ok.
It would fit in the most logical loop, so it depends on where you're mounting everything else
my CPU block is copper/plexi but my graphic blocks are Acetal+EN (Nickel) read some where not to mix metals does this mean i will have to have two loops ?
