What do I need?
2 Aug 2016
Third Earth
Hi guys,
Looking for some advice.
I have 2 PC's and one set of speakers.
The speakers have RCA to phono which go into the back of one of the PC's, I want to have both PC's connected to the speakers.
I initially bought a phono splitter but the quality was really bad so I then got a little Bluetooth dongle as both of my PC's have BT.
The problem the BT isn't great either.
Is there a device, like an amp? Something I can plug the speakers into and both PC's and just select any PC as I want?
Any ideas?
I made myself a switch to switch between 3.mm outputs (speakers and headphones). Relatively simple if you can solder.
Otherwise, look out for an A/B switch. Plenty of RCA/Phono ones out there, not so many 3.5mm but you can use adapters.
