Backstory:
My 7950x3d was working perfectly since I bought it nearly 2 years ago. Turned it on one day and it gave me 00 memory code and wouldn't boot no matter what I did. The board is an Asus X670E Extreme, seems fairly common if you look online.
Tried the normal stuff: Resetting bios, swapping to second bios, different PSU different ram, nothing works. Either the CPU or mobo was dead, no combination of troubleshooting would get it to post.
I tried multiple times reseating the CPU and checking it for obvious damage. Nothing. But during my frustrated trial and error I managed to bend some pins on the socket of the board... so now I can't even RMA it. I've sent it to Joshi repair to see if it can be fixed.
Meanwhile, I was able to get a good deal on a NZXT B650E board from a competitor (new in box, no sign of use around screw holes or socket). I was planning to upgrade my server later this year anyway and figured that could be the first part. Got the board, tried the 7950x3d in it... won't post, two red leds for DRAM and CPU. Aha! I thought, dead CPU. Off to AMD warranty it goes.
In the meantime, I need my pc for work so grabbed a 9950X from OCUK, surprisingly good value at the moment so figured I'd use either that or my 7950x3d for an overkill server upgrade when the replacement comes in. I used BIOS Flashback on the NZXT motherboard to make sure it would support the 9000 series, then went to boot with the 9950X. Two red leds for DRAM and CPU. Exactly the same result as the 7950x3d.
And that's where I'm at... now what? I'm thinking either:
- The 7950x3d was fine and it's going back to AMD for them to return it but the original X670E board was faulty before I bent the pins AND the B650E board is faulty on arrival.
- The 7950x3d died and the 9950x is DOA
- The X670E board died and the CPU was fine, but then was killed by the B650E board, which also killed the 9950X
- The 7950x3d died in such a way that it also killed both boards and that's why the 9950x won't post
This is turning into a potentially very expensive set of failures and I've no idea what to try next. I'm also frustrated with how much I'm likely going to have to send back before I get a working PC again. While it's my own fault I bent a pin, I wouldn't have had to take the CPU out and try reseating it several times if either the original board/cpu hadn't died randomly.
At this point I have never seen either the 9950x or the B650E board boot successfully so I'm back to where I was with the previous board and CPU.
