What do I upgrade next?
16 Apr 2018
This is my pc. Which component do I upgrade next?
GPU: ASUS Cerberus GeForce GTX 1070Ti 8GB GDDR5 Advanced
CPU: Intel i7-8700k
Motherboard: ASUS Intel 1151 Z370 Prime-A D4 ATX
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 3000MHz
PSU:
EVGA 650 GQ 80+ GOLD 650W
CPU Cooler:
Cooler Master Hyper 212 EVO
WIFI CARD:
TP-Link Archer T9E AC1900 Wireless Dual Band PCI Express Adapter
I play Call of Duty Warzone, Counter Strike and Diablo.
Looks fine to me (assuming you are happy with your SSD, monitor and other peripherals).
If you really, really, really want to upgrade, CoD and CS will look a bit shinier with ray tracing if you change the GPU to an RTX 20?0 or 30?0
Not sure about tech stuff, but i would be thinking that graphics card, possibly a new 3070 or 3080 card would go well, hoping that your motherboard supports it.
what res do you game at ? and at 1080 or 1440p monitor ? any upcoming games your looking to play, get the best out of ?
Thanks for your responses guys.
I do need to buy another SSD as mine is only 250gb. I am going to look at buying a 1TB SSD.
My monitor is 1080p, 144hz, 1ms, 24". Its the Acer Predator GN246HLBbi. I am thinking of upgrading my monitor too.
So perhaps my SSD and GPU next then?
1 TB SSD and a 3080 graphics card if you can get one would be great upgrades, then if you have any funds left id say go for a nice ultrawide monitor around christmas time
No sense to start thinking about upgrading GPU, until that rather small low resolution monitor has been updated to something modern.
Just as an example 27" 2560x1440 monitors start from £300 and below.
https://www.overclockers.co.uk/aoc-...een-led-backlit-gaming-monitor-mo-057-ao.html
https://www.overclockers.co.uk/acer...r400-widescreen-gaming-monitor-mo-14b-ac.html
https://www.overclockers.co.uk/giga...ed-backlit-widescreen-gaming-m-mo-009-gi.html
