What do people use to rip CDs these days?
Suspended
3 Mar 2003
London ;()!
Hiya,
My band have had a CD mastered and we want to make mp3s from the tracks the studio gave us.
In the past I used to use AudioCatalyst - a bit old and it meant installing an ASPI driver but it was very quick.
Now I find in the days of ipods that audiocatalyst doesnt make a proper id3 tag and surely something better must be out there now?
So I tried CDEX... my god that was slow (even with drive speed turned up).
Am currently trying EAC - it has to pause inbetween ripping each track to load LAME when audiocat would've been finished minutes ago!
What's going on?!
Chronos-X said:
Back in my day audiograbber could only do .wav. Can it do MP3 and id3v2 now?
Definitely does MP3 but I tag my files with ID3-tagit anyway (another free prog).
just noticed I have a tick mark on my ID3v2 in Audiograbber settings.
So YES.
That must've been AGES ago. I remember using audiograbber back in the days (2000?) to encode/test LAME and BladeEnc after using it to rip CDs. I think they had to be setup similar to the way EAC need to be setup though. No built-in codec if I remember right.
It was around '98-'99 iirc. You had to rip a 40mb wav (which on a 1gig HD you would feel the pinch of) - then set Lame up as a DOS command to make the mp3, which usually took a few minutes.
Anyway thanks for the recommendation poolio, its just like an improved AudioCatalyst now :) Shame about the still crap file browser though.
You probably remember that Audiocatalyst was the daddy under Win95 and then I think it stopped working correctly under Win98 and didn't work at all under XP.
We had to find new ways to encode and a few years ago I asked the same question on these forums for a free ripper.
I was gobsmacked when I saw Audiograbber because it was a blast from the past.
I think that's how mine worked. Audiocatalyst could be setup to automatically launch LAME/BladeEnc and piping the right syntax to it right? That's also how EAC, which I use now, work (at least for FLAC). However the ripping doesn't stop in EAC while you encode, which I forgot if it did in Audiocatalyst.
