Guys with AMD CPUs seem to be the most ardent AMD gpu defenders too I've noticed![]()
It is small man syndrome
I began playing borderlands 2 on my 6950 with physx on low, then I upgraded to a 670 and banged physx onto high. I cant say theres a massive difference either way and tbh theres parts of the game where the physx has caused me some pretty significant slowdown so my physx setting is now on medium because of it.
It is small man syndrome![]()
Lol I have been reading the CPU section and it is just as bad as here. If anybody dares slate AMD CPUs, they get pounced on big time.
So that makes it ok to throw insults at someone in here, especially someone who does not even behave like that?
Nice.....
Point proven. Nothing said was personal at you that I have read.
2560x1440 isn't the sort of resolution that starts to make a difference. Yes ATI catch up with the higher resolutions but it isn't until you get to 3 monitors that you benefit from one over the other in the resolution department.
OpenCL based direct compute advanced AA, advanced lighting........
Look in games like Nexius / Dirt Showdown...........
Obviously I have no proof either way, but I doubt Nvidia cant do those effects in those games. Seem pretty simple, plus those games are not exactly AAA titles.
I'm the only one here with an AMD CPU in my signature
Nvidia games are better than AMD games, so that's what would keep Nvidia prices high? okay.....
I't's early days yet, the point is AMD are starting to add in things like that. more titles will surely follow.
Besides, i actually quite like Dirt Showdown.
Are you small?
A few months after release AMD and Nvidia drivers are usually equal. I would have to say though that from experience, while both companies mess up, I would have to give nvidia the edge for stability with early driver releases. At this point in the current generation though the difference between the two is negligible
It's plainly an insult http://www.urbandictionary.com/define.php?term=small man syndrome
And ironic that he resorted to it, how does the saying go? "you point a finger at someone and you have four pointing right back at you"
How far are you in? The effects later on are quite eye catching.
If you feel insulted, report it.
