What do you advise me?upgrade
7 Nov 2018
I will now have an i7 [email protected] ghz 8gb ram ddr3 1333 mhz and a gtx 980 ti @ 1510 mhz I can upgrade to an i7 8700k + ddr4 2400 mhz + asus rog strix z370g or I can maintain the platform and buy a rtx 2070 (in my country both things are the same) if you chose the rtx 2070 I can update the ram to 12 gb 1600 mhz too, the idea is to play 1080p +60 fps and in the future 1440p 60 fps, although I would update my monitor by the end of 2019, Sorry for my english im using Google translate
Tricky one there. A modern GPU would be fine with that CPU, especially if we're talking 1440p, however I would be reluctant to put more money into the current platform as 1333mhz DDR is going to cost you some performance. These older i7 CPU's are ok but work best with new graphics cards when you have 2400mhz+ DDR3.
The setup you have is still worth quite a bit second hand. My advise, sell up and move the a stronger platform with high speed memory that could get the most out of a 2070.
