What do you think is causing this problem guys?
17 Jul 2015
Hi PC spec is in my sig. I'm having an issue with Call of Duty Warzone and every now and then in certain places I get a red, white and sometimes green flashing over a large portion of the screen. My FPS ranges from 70 odd to 120.
I'm overclocked but have never seen this issue in any other game and I can't replicate it during a gpu stress test. I have removed the overclock but still have the issue. Any idea?
Looks like probably a driver issue.
If not then possibly memory overclock on your graphics card?
Does anyone else get it? Have you tried turning down the memory speed on your graphics card to below stock?
I did remove the driver and did a clean fresh install but that didn't change it. I had updated my driver today and haven't tested yet so hopefully that will fix it.
I completely removed the overclock from my gpu but the problem still persists.
Unsure if anyone else has this issue atm. I'll try to detune my gpu to see if that helps. My temps never go abopve 45c.
i believe this is a known issue with the game, i have it also, but not quite as bad as you. mine is usually just a quick flicker as though somebody has a laser on their gun. Maybe a game reinstall?
That's good to know guys. Now about to try it with a new driver and I have also installed the shaders again. It's not normally that bad, I just caught it at a bad moment and thought I'd video it for fault finding.
