What do you think of this parts?
20 Aug 2007
Hey guys i'm looking to order some parts to build a PC tomorrow, i'm gonna use a mATX case as i don't want a big tower in my room. I was just wondering what you thought of these parts? Will they be okay together and be able to OC a decent amount?
Thanks.
for the CPU, if you want to spend £130, get the e8200 and have a 45nm chip instead, otherwise get a e2200 and just OC it.
check the lengh of the GTS before buying to ensure it fits.
a HX520 is enough especially if Crossfire or SLi is not needed
as above, you may want to go for ATI card :) such as the 3870 as they are smaller :)
the 520w psu will be more than adequate :)
otherwise thats good, check the bezel on the front of the dvdrw is the same colour as the case :) a white bezel on a sexy case looks .... bad!
