What do you use for recording?
8 Jan 2009
North East
As the title says, what do you use for taking screenshots / recording gameplay? Fraps is pants tbh, so would like some suggestions.
Also, I think this is impossible but, incase its not can you take a screenie ingame without all the game HUD stuff showing up (such as health, speedometer, lives, time etc)
Cheers :p
In source games, the demo feature. You can configure the HUD etc so everything is turned off and you can record in 300+ fps and post process your videos so they're really smooth. It's difficult to use but it's a really good system I think.
For non source games, Dxtory is just like Fraps except vastly superior. You have to buy it though, the trial's watermark is unbearable.
Thats the first I've heard of that. I'll have to check that out soon. ¥3,600 = £27.24 vs $37 = £22 for Fraps. Fraps can be a bit of a pig at times with some games.
I used to use FRAPS but have been using the MSI Afterburner for a few months now, I have it set so it shows my FPS, GPU temp & % fan speed as well as taking screenshots and recording videos.
I never actually record while playing very often, I only really record demos (CoD4), so Fraps provides me with acceptable quality for that.
For screenshots I just use Xfire.
I use Steam for screenies now so I don't have to remember to load it up, but I'm also after a decent recording application. I used the trial of FRAPS, which is decent, but haven't tried anything else to compare it to.
I used to use Camstudio to record my games when I was playing 5 wow accounts - videos everything on screen, and in good quality. Free too.
If you think Fraps is pants then you need to get the newer versions.
Framerate lock = disabled = smooth video recordings at very high quality even at full res mode.
I an play at 60fps with Fraps recording at 1920x1200 in my usual games (L4D2, Portal 2 etc).
FRAPS has worked for me, Up until a few weeks back were I couldn't view the clips I had recorded in MW2/Black Ops. Soon fixed that with changing my default player to VLC.
VLC Rocks :D
I dont get lag, my rig is good:
OCZ ModXStream 700W
Phenom X6 1055T 3.85GHz
MSI GTX 460 Hawk 850/1700/4000
2X2GB DDR3 G.Skill 1800Mhz
M4A88TD-V EVO
I play at 1920x1080 res on a 40" Samsung TV, its not lag, Just the video recording sizes are huge, like over a Gigabyte which is no good for Youtube :eek:
OCZ ModXStream 700W
M4A88TD-V EVO
You do know that FRAPS records as a raw .avi file, hence the large files?
You then have to simply encode the footage to a suitable format (MPEG/WMV/Whatever else) and that will drastically reduce the file size.
