What do you use for stress testing?
18 May 2010
Hi,
I know it's old but I was using Heaven to OC and UV my Vega 56.
I got it to 1600mhz after loads of tweaking with Heaven running in window mode and was happy with everything.
When in game I don't use an overlay but sometimes I have HW monitor in the background and check it when I've finished gaming and the GPU reported hitting 1700mhz which is a massive difference to what wattman reported with Heaven running.
What does everyone use to stress test and OC and then monitor in game? I think I'm a bit behind with the software I'm using!
Thanks
Heaven and Valley as IMO the former will show errors in Core and later will do the same for Memory, I can run 2100mhz Core looped X times in Valley but not quiet stable in Heaven so drops a notch or two.
I just set up my overclock , then put it in a room with my Girlfriend for 24 hours , no need for realbench or prime , if it passes that stress test its bomb proof
Hi,
Thanks
Metro Exodus, Gears 5 and BFV all run at 4K max settings for a minimum of 1 hour each, As for monitoring I use Hwinfo64 and Afterburner.
This is golden hahahaahahahahahahahaha XD
Ok thanks, let's rephrase slightly
Why did heaven max my GPU out at 1600mhz and actual gaming caused it to hit 1700mhz
Heaven doesn't report clocks properly, According to it I'm running 2100MHz on my 2080 Ti when in actual fact I have it sitting at stock settings of around 1800MHz, Personally I'd only use either Hwinfo or GPU-Z to monitor clocks.
Example, Heaven vs actual clocks.
For memory OC: AC Odyssey
For Core OC: Witcher 3
General OC performance: Ashes of the Singularity & Strange Brigade & Shadow of the Tomb Raider
I'd only use synthetics for the quick & dirty OC to know what the limit is real quick, eg 3dmark. But ALWAYS fine-tune it with actual games. This is with a V64.
I’ve always found the Battlefield games are very sensitive to an unstable overclock. More so than any other game I’ve found.
Just play games. All this stress testing with heaven and other benchmark programs is a waste of time really. Games stress your system in ways that benchmark programs don't.
Hi,
Thanks
Timespy graphics test 2
