What does everybody think?
29 Dec 2005
spent a bit of time on my benchmarking last night
3d Mark 01
3d Mark 05
3d Mark 06
Has anybody done better than these, not trying to be big headed, but if they have it would be nice to compare
Lookin good mate :D There are loads of threads/tables in here for you to compare,if you care to look
Search is your friend ;)
Rob
welshtom said:
could probably do a higher 01, but the others are untouchable with single card setups :)
good scores
:confused:
But by looking at his sig his running two x1900 cards in crossfire to get them scores..
if you want to do proper comparisons then why not fight it out on the orb? There is no way your scores will top out on there... so will be a good place to find out what matches your rig in the real world.
only problem is that most people dont specify what type of cooling they use which makes it hard too work out how you are doing
You can safely assume that most people on the ORB with FX60s at 3.4GHz+ are running phase.
Hav
