SPD stands for Serial Presence Detect and it is basically the motherboards ability to read a small chip on a stick of RAM that contains all the timing information. For everyday use leaving the motherboard to do this by itself is fine.
However, when overclocking [or sometimes when not] some boards change or even completely ignore the timings. It is generally recommended to set the 4 main timings yourself in the BIOS [ie 4-4-4-12 for my RAM].
Yep, it basically tells the MB what RAM timings to use and are nearly always on the conservative side and not as tight as the rated timings the RAM is actually sold at. It's nearly always better to manually set them to the correct timings.
Yeah deffo set them yourself, cos some SPD timings on some sticks are wrong (like my GeIL SPD timings for 400mhz). You can usally check the "optimal" timings for your RAM on the manufacturers website, so manually set them to that.
