- 8 Feb 2020
https://imgur.com/a/Nr5ptnF
Hello, What does the setting in the picture mean - I was having problems streaming to my TV untill I changed this setting from the default witch was one of the dual band ones.
I assume it means if it HAS to oparate in the specific a/b/g Protocol(s) which one to use? but what does the "/" mean on 802.11b/g (the setting I changed it to). Does it mean the computer will pick where as "802.11b" and "802.11g" will ONLY use that one selected?
so should I leave it on 802.11b/g or change it to 802.11g or 802.11b
Thanks.
Thanks.
