What drivers do I need?
26 Jan 2010
Ive just reinstalled windows 10
Mostly to reinstall using the new UEFI bios, no more 3080 4 beeps warning
I see installing with UEFI is so much better, i mean start up screen looks way better
But what drivers do I need>?
Ive got the X299 Asus Strix board, the driver disc is useless as i havent owned a CD drive for 2 years now
The list includes:
Intel turbo boost drivers
Lan Drivers
Chipset Drivers
Sata Drivers Intel(R) Virtual RAID on CPU Driver V6.2.0.1239
https://dlcdnets.asus.com/pub/ASUS/mb/05SATA/DRV_VROC_Intel_HEDT_TP_W10_64_VER6201239_20191108R.zip
Ive already got wifi running and blutooth running without any drivers installed
Anything else i need or doesnt windows install all the drivers i need automatically?
Most of the drivers for your motherboard from there website.
Chipset
Usb
Lan
Wifi.
You don't need vitual raid unless you want to use it.
Windows should update them if needed.
You probably won't need any drivers for x299. I'd just download them if something doesn't work properly, or is using generic.
its quite difficult to see what i need, example usb drivers, i cant find them for the asus strix x299
wifi i manually downloaded
What about intel turbo boost 3.0? do i need that....
