what engine light is this?
Done some light Googling and it does look like it may be water contamination. Would it be save to drive around 50 miles. In the middle of nowhere and can drop it at the garage when I get home
Clean it!
I'd probably not worry about it, it'd take a fair bit of water to contaminate a full tank of fuel, maybe just condensation.
Other than the above suggestions; is it a dual tank vehicle (and that's letting you know you're using the reserve tank)? - Probably not, but you see that on Landcruisers.
